Machine Vision
Error 9999 Pixel Transformation Problem
I am having attached error on my VI. The error codes does not explain me much but when I check, the error happens after Vision Assistant step.
When I remove most of the script inside Vision Assistant, the error disappears. Then I add some functions and re-run without problem. Afterwards it is happening again without I change anything.
I was suspicious the error was coming from Caliper step in Vision Assistant but not solved the problem.
Do you know what can be the cause of problem?
(2,391 Views)
Anyone having an idea about this problem?
In development computer, with a calibrated image, I don't have this problem. I can only repeat this problem when I use un-calibrated image inside Vision Assistant script.
So this looks like somehow related with calibration of an image. And Vision Assistant somehow can not read calibration information. In my code, there is calibration steps but I am still having this problem on runtime computer.
(2,300 Views)
