Machine Vision
Vision Builder AI: Issue with "Limit # of Image Files" in image logging tool
Hey there,
i've got an issue regarding the image logging tool in Vision Builder AI.
Setting the option to limit the number of logged images (and so delete the oldest ones if the threshold has been reached) does not work for me on the larger scale. Right now it is set to limit the number to 3000 images, last time i checked the folder, it contained around 20.000 images. So right now i have to check regularly and delete da oldest images by hand to not risk it to fill the disc, which is not realy what you want to have from an automation software 😅
When i try it on my dev pc, it seems to work as it should (at least with with a quite small limit), but not on the production pc with the connected camera.
Anybody knows about this "feature" and how to make it work properly?
Message 1 of 1
(662 Views)
