Machine Vision
Error calibration target to points - circular dots
Hi
Here is my VI where I want to use the calibration target to points-circular dots function to start my calibration.
[URL=https://imageshack.com/i/0ycux2j][IMG]http://imagizer.imageshack.us/v2/xq90/34/cux2.jpg[/IMG][/URL]
This function seems to be quiet easy, yet I've come to an error which I can't get rid of. I think there is nothing wrong with the picture I want to proces, but you never know so you can find that picture in the attachements.
Kind regards
Ruts
(5,528 Views)
excuse me for the bad image link. Here is the direct link: http://imageshack.com/a/img34/5791/cux2.jpg
(5,518 Views)
Accepted by topic author RutsT
you need to threshold the calibration grid image in order to extract the coordinates of the circles.
Take a look at the "Perspective calibration" example in Labview Help -> Find examples.
Also, reading detailed information of the functions you are using will also help:
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,500 Views)
I always read the (detailed) help, but as you can see I visualized my image in my front panel and it says 1032x788 1X 8-bit image. So I assumed that meant it was a binary image.
Thanks for your help, typical rookie mistake from me (not the last).
Kind regards
Ruts
(5,498 Views)
glad to help.
Actually, strictly speaking, in binary image each pixel can be represented only by a single bit (so 0 or 1), while grayscale image (8-bit) can use 256 values. As far as I know, in NI vision, a binary image is represented using a 8-bit grayscale, taking the same amount of memory.
K
(5,489 Views)
