Machine Vision
sir i am using machine vision labview. i want to find usb running camera image x,y coordinate. then i have send that coordinate into microcontroller via labview serial port. please help me?
Message 1 of 8
(5,706 Views)
you are being a bit unclear about what you are trying to achieve. X, Y coordinates of what object are you trying to find? There are a lot of ways to extract the coordinates but you need to specify what properties of your object are you trying to measure (mass center, edge location, etc...)? And perhaps post a sample picture to be even clearer.
Use serial communication to send bytes to your uC. Here is an example (post #10):
http://forums.ni.com/t5/Machine-Vision/eye-controlled-wheelchair/td-p/2651903
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 8
(5,700 Views)
i am doing labview machine vision based robotic arm control for pick and place application. i want know the image x,y coordinate in running camera..give me solution please.
Message 3 of 8
(5,685 Views)
Hi Sekar91
You have working pattern matching code right for the still image?. If so, add the camera acqusition part -> Put a while loop for contionus acqusition -> Match the pattern. It will give you the expected result.
Silver_Shaper | CLD
Message 4 of 8
(5,680 Views)
k. thank you sir.. how i will find image x,y coordinate. which function i use to find image x,y coordinate?.
Message 5 of 8
(5,664 Views)
Almost all the vision functions in LabVIEW give you the x,y co-ordinates.
As seen from your image. Go with the binary processing -> Get the centroid of the image using particle analysis. Example is here http://www.ni.com/example/30629/en/
Silver_Shaper | CLD
Message 6 of 8
(5,657 Views)
like Silver_Shaper said, there are a lot of functions in NI Vision that return the coordinates of the measured property. You have quite a few examples under the Help -> Find Examples section (from pattern matching to edge detection and binary analysis, etc...).
Does your surface always reflect so much light? In all positions? Are you using frontal illumination?
And also, how did you obtain the x,y coordinate in centimeters? You need to calibrate your system in order to do this. Also, if the distance from the camera to the object changes, your measurements will not be valid anymore.
K
Message 7 of 8
(5,652 Views)
sir i am using LabVIEW image
image processing machine vision
software.. i am using Easy cap
USB 2.0 wireless camera..
camera device driver is not support
measurement and automation
explorer... what is problem? give
me solution sir...
Message 8 of 8
(5,637 Views)
