Machine Vision
Error imaq color pattern
hi, I'm trying to do a draft color pattern recognition, but labview gives me this error, I hope you can help me, let the files, thank you very much
Error -1074395384 occurred at IMAQ Match Color Pattern
Possible reason(s):
IMAQ Vision: Invalid color template image.
Message 1 of 12
(7,495 Views)
image of diagram
Message 2 of 12
(7,485 Views)
I can't see your block diagram clearly due to the low resolution, but did you create a descriptor of your color template (using "IMAQ learn color pattern")?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 3 of 12
(7,476 Views)
thanks for reply
Yes i using "IMAQ learn color pattern",  thanks again
Message 4 of 12
(7,470 Views)
Sorry im using, IMAQ Color Pattern Matching and  IMAQ Setup Match Color Pattern
Message 5 of 12
(7,466 Views)
where did you create the image template? Does it have the template info included?
Why is the image template U64 as opposed to the image U32?
K
Message 6 of 12
(7,461 Views)
Hello
template was added to the route shown this in my documents with the name of pastillas1.png
I tested U64 and u32, u32 and u32, to try to correct the error but could not
regards & thanks
Message 7 of 12
(7,458 Views)
like I said, did you learn the color template information using IMAQ Learn Color Pattern prior to template matching? Or did you just create the template using some external image editor?
Check the Color Pattern Matching example under Labview examples.
K
Message 8 of 12
(7,444 Views)
im create the template using some external image editor, i dont know how make whit  IMAQ Learn Color Pattern.
can you help me, please?
regards from mexico
Message 9 of 12
(7,426 Views)
the general idea is:
K
Message 10 of 12
(7,421 Views)
