Machine Vision
serial port working and get result but not asyncronus by timer why
Can any one helping me in this code :
using System;
using System.IO.Ports;
using System.Windows.Forms;
using System.Threading;
using System.Text;
namespace CommSample
public partial class Form1 : Form
string portData = "";
public Form1()
InitializeComponent();
void Application_Idle(object sender, EventArgs e)
label3.Text = serialPort1.IsOpen ? "[Open]" : "[Closed]";
private void button1_Click(object sender, EventArgs e)
if (pollingCheckbox.Checked)
timer1.Enabled = true;
else
timer1.Enabled = false;
TransmitCommand();
private void TransmitCommand()
if (textBox1.Text.Length > 0)
if (serialPort1.IsOpen)
serialPort1.Write(textbox1.text + "\r");
private void ClosePort()
TransmitCommand();
serialPort1.DataReceived -= new SerialDataReceivedEventHandler(serialPort1_DataReceived);
serialPort1.Close();
private void closePortToolStripMenuItem_Click(object sender, EventArgs e)
ClosePort();
private void exitToolStripMenuItem_Click(object sender, EventArgs e)
Close();
private void Form1_Load(object sender, EventArgs e)
serialPort1.PortName = Properties.Settings.Default.Port;
serialPort1.BaudRate = Properties.Settings.Default.Baud;
serialPort1.DataBits = Properties.Settings.Default.DataBits;
serialPort1.Parity = (Parity)Enum.Parse(typeof(Parity), Properties.Settings.Default.Parity);
serialPort1.StopBits = (StopBits)Enum.Parse(typeof(StopBits), Properties.Settings.Default.StopBits);
Application.Idle += new EventHandler(Application_Idle);
private void OpenPort()
serialPort1.Open();
serialPort1.DataReceived += new SerialDataReceivedEventHandler(serialPort1_DataReceived);
private void openPortToolStripMenuItem_Click(object sender, EventArgs e)
OpenPort();
label4.Visible = true;
label5.Visible = true;
private void optionsToolStripMenuItem_Click(object sender, EventArgs e)
ClosePort();
using (Form2 form = new Form2())
if (form.ShowDialog(this) == DialogResult.OK)
void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
string debugMessage = "";
float value;
if (!InvokeRequired)
if (e.EventType == SerialData.Chars)
portData += serialPort1.ReadExisting();
while (portData.Contains("\r"))
string temp = portData.Substring(0, portData.IndexOf('\r'));
foreach (byte x in Encoding.UTF8.GetBytes(portData))
debugMessage = debugMessage + x.ToString("x2");
Console.WriteLine("Debug : " + debugMessage);
portData = portData.Substring(portData.IndexOf('\r') + 1);
if (temp.Length == 12)
char status = temp[11];
switch (status)
case ' ':
if (float.TryParse(temp.Substring(1, 8).Trim(), out value))
//enter code here to process integer
textBox2.Text = temp.Substring(1, 8).Trim();
Console.WriteLine("Parse Number : {0}", textBox2.Text);
else
textBox2.Text = "Not Numeric";
Console.WriteLine("Cannot parse : {0}", portData);
break;
case 'I':
textBox2.Text = "Invalid";
Console.WriteLine("Invalid : {0}", portData);
break;
case 'M':
textBox2.Text = "In Motion";
Console.WriteLine("In Motion : {0}", portData);
break;
case 'O':
textBox2.Text = "Under/Over Range";
Console.WriteLine("Uneder/Over : {0}", portData);
break;
else
SerialDataReceivedEventHandler invoker = new SerialDataReceivedEventHandler(serialPort1_DataReceived);
BeginInvoke(invoker, new object[] { sender, e });
private void pollingCheckbox_CheckedChanged(object sender, EventArgs e)
if (timer1.Enabled && !pollingCheckbox.Checked)
private void timer1_Tick(object sender, EventArgs e)
TransmitCommand();
Notes : textbox2 in multiline mode and my weight bridge weighting is ricelake IQ+355
This is code above working good his result is ok according to weight bridge value
but it is not asyncronusly
i make timer is enabled but also it is not asyncronusly meaning you need close application and open again to take the value of weight bridge
Now How i make code above asyncronusly working and changes when weight bridge in same time
thanks
(5,042 Views)
If your question mainly involves the serial interface to the device you are accessing, I would post this question in the instrument control forums at the below link:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140
Posting a little more explanation behind the application and behavior you are expecting would also be beneficial.
(5,023 Views)
