Machine Vision
Error message after deploy vision software to other machine
hello,
I am working with labview vision software. After deployment to other machine using vision deployment engine, error message appeared. Could you rectify why the error message appeared-" ERROR 25 OCCURED AT INPORT32.VI-LABVIEW EXTERNAL CODE NOT PRESENT"?
Attached is error file.
thanks,
hart
(3,164 Views)
Hey Hart,
Thanks for contacting NI.  I've been looking into your issue and I'm not entirely sure your problem is with Vision specifically.  I found this knowledgebase that should help you out.
It appears that INPort VI's use the Call Library Function Node to call the dll cviVXDWrapper.dll which requires the CVI Run-Time Engine to be installed. If you install this on the target computer, you should be able to run the executable.  I hope this helps you out!
Take Care,
Evan D.
Installer R&D
(3,148 Views)
