Hi Sundance,
Thanks for posting on the NI forums! When you say the VIs ran fine previously, do you mean they were created with the same version of installers you listed? Have you tried a
Mass Compile of your NI directory? It sounds as if for some reason the subVIs in your program are pointing to the wrong directories, and a mass compile would highlight/correct those errors. If that doesn't work, or if you do find subVIs that are broken, replace the subVIs manually in the block diagram, which will replace the old subVIs with subVIs from the LV7.1 library directories.
I hope this helps,
