Machine Vision
FILTER for gray scale camera NI1722??
Hi
I am using a gray scale camera in order to make a program which gives us the distance between the camera and the object.
Application:
this camera will be used in a moving robot to detect  moving objects and calculate the distance between the object and the robot to give a signal to avoid crash.
I tried with the program i joind but I had errors. In fact I found the bloc wich helps giving the distance (edge detection) but now i am bocked because in that program I used a filter which not appropriate with the grayscale camera.
PS: choose HL grab edge when opening the program
Message 1 of 1
(2,866 Views)
