Machine Vision
Failed to load NI-Vision development module library
Hi all,
I am using Labview 2014-64 bit with vision, but every time I try find some vi in vision development module llb I get this error msg:
failed to load dynamic library because of missing external symbols.
screenshot attached.
I tried to load vision development with selecting 64 bit support twice but still getting the same error msg.
can any one tell me where can be the problem.
thanks
(5,164 Views)
Hi AnkitG,
One thing to make sure of is that you have installed the correct version of software. You would need Vision Development Module 2014 f1, which can be found here:
http://www.ni.com/download/vision-development-module-2014-f1/4971/en/
If you are installing from a CD, please try uninstalling and then reinstalling using the link from our website and then follow these steps:
http://digital.ni.com/public.nsf/allkb/7B71A26E9B4891C6862577C9007B3F27?OpenDocument
Please make sure the version of LabVIEW selected is the one you are using. After restarting the computer after installation, please try to access the pallette again.
Paolo F.
(5,128 Views)
