Machine Vision
Maybe there is an error in the SVD Decomposition.vi
I use the SVD Decomposition.vi to analyze the matrix F.Then I did the same thing in the Matlab,the two answers is not the same.Anybody can help me?
Change the world
(5,404 Views)
A red Dot near your input to SUV is indicating change of data type. results gona be same if your data type is same in both cases
Latrobe Student
(5,390 Views)
Thank you for answer me.Even though I change the data as you told me,the answer is still different.I don't know why.
Change the world
(5,385 Views)
Did you use the full decomposition in both cases? Labview default is thin decomposition while matlab default is full decomposition. I don't know if this should be a problem anyway.
(5,367 Views)
Thank you for answer. As Chinese is my mother tongue, the word "完整" in the bule table is the full decomposition . I still don't know why it is different.
Change the world
(5,356 Views)
