Machine Vision
False Color Map using palette option
Hi all,
There's a palette option where you can create an 8-bit greyscale image into different "color maps". The same can be done prgramatically using property node.
Now, I need either a "gradient" or "rainbow" type palette where I can set a range of colors to be mapped.
For example I want the image below
to look something like this,
the above image takes shades from red to green. Any help is appreciated.
Message 1 of 8
(6,919 Views)
To create a User Palette, you need to create an array that will map each pixel in your image to a new color value of your choice.
The User Palette is an array of clusters with three integer elements in each cluster representing the red, blue, and green components of a color. Each cluster represents a mapping for one pixel intensity value in the image. For example, for an 8-bit image capable of 256 different intensity levels, you can have up to 256 color values in your palette, one color for each intensity value.
Ref:http://digital.ni.com/public.nsf/allkb/93C942F30387957D86257BBA0080DEF1
uday
Message 2 of 8
(6,900 Views)
Can you fix broken link?
Message 3 of 8
(6,020 Views)
Attached is a LabVIEW library where I mapped all of the MATLAB options for color palettes.  See if one of these works.  I don't remember what all of them look like.  I believe this copy is from LV 2011.
Randall Pursley
Message 4 of 8
(6,013 Views)
Thanks a lot for the sharing of these color palettes and the tester VI with an Intensity Graph and an Image Control, rpursley8
It's helpfull !
I am curious to know where do you find or how do you calculate the 256 values of RGB U32 for each palette.
I am searching the color table of 256 values corresponding to the Red (Positive) Blue (Negative) colormap (like the sreenshot)
Could you help me to build the colors table please ?
Message 5 of 8
(5,313 Views)
I have found.
It's easy to add new color map to the .lvlib shared by Randall by downloading the color tables on a website like this : Color table gallery
For instance, the files with the extension .rgb contains the 256 values of the colormap that I searched : RGB table of "CoolWarm" table
Message 6 of 8
(5,296 Views)
This will generate the color map you want
Randall Pursley
Message 7 of 8
(5,255 Views)
Make sure when you add that new class for this color map that you do 'Make Current Value Default' once you put the values in the class control.
Randall Pursley
Message 8 of 8
(5,221 Views)
