Machine Vision
Find IP programmatically CVS
Any body know how to find the IP address programatically in CVS.
thanks
(4,032 Views)
Puradchi,
Great question! If you are programming in LabVIEW, you can do this by using the VI called "RT Ping Controllers.vi" located at All Functions>>Real Time VIs>>Real Time Utilities. That will return an array of clusters containing information about any RT targets on your network.
Now, let's say you need to isolate just the IP address- use the "Index Array" function to isolate just the target you want, and then use "Unbundle by name" to unbundle the IP address from the cluster.
I attached a little example for you that does this. I had 2 RT controllers on my subnet, with the CVS being the 2nd. That is why I indexed out index 1 (indices were 0 and 1) and unbundled from there. Hope this helps you out!
Regards
Dan
(4,020 Views)
(4,017 Views)
DannyQ,
Thank you for your VI. It solved my problem
Puradchi
(4,011 Views)
