01-20-2011 10:19 AM
Hello all,
I'm facing a problem and in this moment it´s missing a good idea 🙂
I need to find the brown part on a pear that is near the stick. In attach you can find several fotos.
Thanks in advance,
Carmo
01-25-2011 01:46 AM
Hi Carmo,
Thanks for posting on National Instruments forum.
Can you tell us which software you use?
01-25-2011 07:45 AM
You can use color segmentaion to segment the brown part of the pear. I have attached the classifier file, vision assistant script and sample segmenation.You can improve the quality of segmetnation by enabling "refine segmentation" and adding more samples to classifier file.
09-19-2011 08:34 AM
Hello all,
I believe that the color segmentation can be very helpfull, but I'm facing some problems with this.
Can I have a code example that is using this principle?
I already try to find in site, but I didn´t find.
09-19-2011 08:37 AM
it's seams perfect.
can you explain me how did you make that?
