Machine Vision
Find the brown part on a pear.
Hello all,
I'm facing a problem and in this moment it´s missing a good idea 🙂
I need to find the brown part on a pear that is near the stick. In attach you can find several fotos.
Thanks in advance,
Carmo
(3,543 Views)
Hi Carmo,
Thanks for posting on National Instruments forum.
Can you tell us which software you use?
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,463 Views)
You can use color segmentaion to segment the brown part of the pear. I have attached the classifier file, vision assistant script and sample segmenation.You can improve the quality of segmetnation by enabling "refine segmentation" and adding more samples to classifier file.
(3,457 Views)
Hello all,
I believe that the color segmentation can be very helpfull, but I'm facing some problems with this.
Can I have a code example that is using this principle?
I already try to find in site, but I didn´t find.
(3,306 Views)
it's seams perfect.
can you explain me how did you make that?
(3,305 Views)
