Machine Vision
Firewire B interface recommendations
I am using a HP Elitebook 8440p and would like to interface to a Firewire b camera. Does anybody have any recommendations for ExpressCard interface devices that will function properly with IMAQ dx?
Thanks!
(4,099 Views)
I confirm that IOI is a good solution, I always use these boards.
You can also use the FireWire A port that we can find on most laptops, but don't forget that on PCs these ports are not powered, you will need a powered
switch to go through.
Regards
(4,088 Views)
....but if one uses a 1394a port with a 1394b camera, one only gets 1394a bandwidth.
(4,085 Views)
Of course Smiley Tongue
(4,084 Views)
