Machine Vision
Grabbing chunk data with a Basler GigE camera
I am trying to access a digital input to a Basler ACE camera using chunk data and LabVIEW but I am having little success.
I have been able to make the following settings to the camera (as per recommendation in the previous post):
Chunk Mode Active           True
Chunk Selector                 Line Status All
I have also tried to enable the IMAQdx driver to use the chunk data by setting ChunkDataDecodingEnabled to true. However, when I try to do this LabView returns the error “Attribute not supported by camera”. According to the Basler manual though, chunk data clearly is supported.
Can you make any suggestions on what might be going wrong? Is this a camera issue or a Labview issue?
Many thanks
Tom
__________________________________
Other details:
Camera model                  Basler ACE AC640-100gm
Camera SN                      2103220
NIC model                        Intel
NIC driver                         Basler driver 1.4.2.49156
Software                          LabVIEW 2009
Software driver                 IMAQdx 3.7
Message 1 of 1
(3,911 Views)
