Machine Vision
Four Cameras to Inspect Label Presence / Date / Lot Code
@+39 0376 263525 wrote:
Hi Muks,
What is the diameter and the height of the bottle and the area of inspection? I would like to confirm if the lens will fit the inspection or eventually suggest an alternative solution.
Alena Verameyeva
Opto Engineering, Italy
alena.verameyeva@opto-engineering.com
+39 (0)376 263525
Thanks for asking. I have anyway asked for the lens to be purchased. Mirza is the original poster and even i am waiting for his response.Smiley Happy
Message 11 of 14
(1,384 Views)
***Double post*** deleted
Message 12 of 14
(1,383 Views)
Hi Muks,
Sorry for my delayed response.
"Can you(Faisal Mirza) give an approximate value and the camera available?"
The camera has a 1/3" sensor and the diameter of the bottles is 40mm (if thats what you asked for?). However, the height of the bottles (in our case 102 mm) don't allow for a complete view of the print present on the lower part of the label.
If you go with the Pericentric lens ultimately, Alena is the right person who worked hard to give us these results in a timely fashion.
Sincerely,
Message 13 of 14
(1,371 Views)
Hi Muks,
Probably you're in touch with one of my colleagues. Anyway, might you need any additional technical information, feel free to contact me or my colleagues.
Special thanks and "hello" to Faisal.
Alena Verameyeva
+39 (0)376 263525
Message 14 of 14
(1,362 Views)
