12-03-2018 04:12 AM
Hi everybody !
I want to use Geometric Matching tool that I watched out in a YouTube video...
but unfortunately I couldn't find it in my Vision Assistant 2018.. is it somewhere else ??
a screen shot from vision assistant menu . there should be a geometric matching option below pattern matching option
thank you and sorry for my elementary question
best regards
Eric
12-03-2018 06:18 AM
this is the YouTube link that I mentioned in the first post :
Geometric Matching
12-04-2018 09:03 AM
Hi ! Did you tried the Pattern Matching, it includes all the functions, but it opens another window
12-04-2018 09:21 AM
In Vision Assistant 2018, we combined all pattern matching steps into one.
When you select the pattern matching step, in the Options tab, you can switch between all pattern matching algorithms, including Geometric Matching. This allows to easily compare the different algorithms and select which one works best to your application, as opposed to having to try out different steps.
Hope this helps,
Christophe
