Machine Vision
GigE Vision Multithreading Problem
Maybe there is a better way to add more than 1 template in the pattern matching?
How would i go about doing that?
20027i186C51944D61ACAB
Krispiekream
Message 41 of 45
(1,980 Views)
does anyone know how to work on this problem?
Krispiekream
Message 42 of 45
(1,837 Views)
The Setup Match Pattern VI does allow for rotated matches to be found, but it does not have an option to search a range of scaled patterns.
To use multiple patterns, I think you would have to set up each pattern and then search for each pattern individually (basically just multiple pattern matches).
Justin D.
Message 43 of 45
(1,817 Views)
do you think labview can take this source code and use it in labview?
http://info.ee.surrey.ac.uk/Personal/Z.Kalal/tld.html
if so, how would i do it?can you give me links to read?
Krispiekream
Message 44 of 45
(1,800 Views)
Hey krispiekream,
It looks like this is using C DLL, so you can use a Call Library Function Node, to bring this in.
See this Tutorial: An Overview of Accessing DLL's
I hope this helps.
Ricky
Message 45 of 45
(1,793 Views)
