10-03-2007 04:02 PM
10-03-2007 08:04 PM
10-04-2007 12:44 AM
Hi Gretchen,
The camera validator utility window is vanishing because it is a command-line utility. If you just click on it when it exits with an error the window will just close. It is meant to be accessed from the command line so that you can pass arguments to it regarding which camera to test and which tests to run. Without any arguments it will run on the first camera found.
Since MAX is giving an Unable to Load XML error, it is not suprising that the utility would give the same error. Both applications need to open the camera and that is when the file is loaded. Assuming you have cleared the XML file directory to remove any corrupted files, I am suspecting that your camera does have an invalid XML file in its firmware. Do you see an XML file downloaded to the XML directory after trying to open the camera? If you click on it does it open in internet explorer without any parsing errors? Can you possibly attach it to a post?
-Eric
10-04-2007 10:15 AM
10-04-2007 10:24 AM
10-04-2007 10:39 AM
10-04-2007 10:43 AM
10-04-2007 10:49 AM
10-04-2007 11:08 AM
10-04-2007 12:43 PM
