Machine Vision
Grayscale (SLG) to HUE
I have a really simple question: after processing the images coming from my camera, I get grayscale (SGL) images. I would like to colorize those images with a cyclic color palette (Type HUE woul be perfect!).
Any simple Ideas? 😉
Thank you in advance.
mathias
(4,490 Views)
I am not quite sure what you mean with "colorize". Do you want to transform a grey-white picture into a for example red-white picture?
(4,460 Views)
Hello Reschri,
Thanks for your interest!
Colorize is not the right word, you are right. I have a picture (SLG values) that I would like to display pseudo-coloured. I would like the color palette to be cyclic (maximum value has the same color as minimum value).
(4,457 Views)
A few of methods:
Have you tried changing the display palette?  There are a couple of nice color mappings, but neither cycle.
You can create a palette lookup table that contains a color for each level of grayscale.  That might take a little work, but you get exactly what you want.
Quick and dirty: create a couple of images the same size with the saturation and intensity levels you want, then combine them with your grayscale image (as hue) into a color image.  I would start with levels of 128, then adjust.
Bruce
Bruce Ammons
Ammons Engineering
(4,455 Views)
Hello BruceAmmons,
Thank you for your answer. Indeed, there are some nice color palette alredy built-in, unfortunately neither cycle... It will come may be...
I will create my own color palette as you proposed, do you know if I can create a 16 bits one or if I am limited with Labview to 8 bits?
Mathias
ZHAW
(4,443 Views)
Accepted by bmat
(4,434 Views)
I got it... Thank you very much!
By
(4,431 Views)
