Machine Vision
How I can make a note on an image in the IMAQ browser?
I searching for the way to add a text on a thumnail image in the IMAQ browser.
I just ran Browser Example.vi and tried to add a note on a thumnail image using IMAQ Overlay Text API.
And also tried adding Overlay Text on the source image and then add that source image to the IMAQ browser.
But both way failed to make it work!
So.. Is there any way I can add a text on the image in the IMAQ browser?
Thanks for your help!
YoungMin
(3,247 Views)
You need to add a text overlay to each image, then merge the overlay with the image before it's loaded into the image browser.  Look in the sequence frame 1 of the outer sequence structure in the attached VI.
(3,107 Views)
