Machine Vision
Labview : Failed to load shared libraries nivision.* in RT
I am trying to run the Roaming.vi of the Starter kit . i have modified it to show an image in the front panel.But , while deploying it is giving error:
Failed to load shared libraries nivision. in RT...Can somebody help me with this.
Harsha.
(3,408 Views)
Are you working while targeting a real-time target?  Did you install "NI Vision RT" onto the target?  It should be in your list of software available to install on the target in Measurement & Automation Explorer.
(3,228 Views)
