Machine Vision
How can I acquire image from usb camera for a win 7 64 bit OS?
Hello~
Please refer to the following link :
http://forums.ni.com/ni/board/message?board.id=200&message.id=28741#M28741
If my OS is 64 bit Win 7,how to register ImaqDirectShowExport.dll successful?
Or it couldn't happen for a 64 bit OS.
The Labview version is 8.0.
Thanks for the reply.
(3,785 Views)
Can you use IMAQdx (part of Vision Acquisition) instead? It is fully supported by NI and is fully tested on all the various OSes we support, including Windows 7 x64.
Eric
(3,777 Views)
Hi BlueCheese
Do you mean that IMAQdx support usb camera even for vision developement module 8.0?
I thought IMAQdx support USB camera only for Labview 2009 version.
Please refer to the link:
http://zone.ni.com/devzone/cda/tut/p/id/10111
Thanks a lot~
(3,774 Views)
The USB/DirectShow support was added back in Vision Acquisition 2009. This is independent of the version of LabVIEW used. However, I believe Vision Acquisition 2009 only supported back to LabVIEW 8.2 or so (I might be wrong, but I am certain it doesn't go as far back as 8.0).
Eric
(3,767 Views)
