I need to be able to track the postion of a camera. The camera is mounted in a fixed position, but has the ability to pan, tilt & and zoom. Without adding sensors to the camera head, I need to know the amount that the camera pans, tilts, and zooms, based on the video coming out of the camera. The camera would be focused on a football field, so there are reference marks available, but there would also be people on the field. This also needs to be in real-time (30fps). Any idea's?
I have included an image of what the camera would typically see.
Thank you,
-Dave
