Machine Vision
How can I fetch an image from CVS-1454 into LabVIEW?
I am developing a LabVIEW configuration application to allow me to configure CVS via ethernet from my PC. Therefore I need to snap an image from a IEEE-1394 camera connected to the CVS and save the image in my PC. I need the LabVIEW application to run on my local PC, not on the CVS. Is there a VI that fetches an image from the CVS?
(3,065 Views)
As of right now there is no way to fetch an image from the CVS system using LV. You could download a VI to the CVS and have it send back images, but that violates your "I need the LabVIEW application to run on my local PC, not on the CVS" rule.
Nicholas C
Applications Engineering
(3,047 Views)
