Machine Vision
How can I get a list of all the IEEE-1394 cameras defined in MAX?
I can use the DAQmx_System:Global_Channels property node to get all the global DAQ channels that are defined in MAX, but is it possible to do something similar to get all the camera names?  I'm specifically after all the IEEE-1394 cameras, but would be happy with a list of all cameras to start with.  Is there a property node that I'm over looking?
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 1 of 10
(5,101 Views)
Accepted by topic author crelf
Hi, Christopfer,
You can use IMAQdx Enumerate Cameras.vi for getting the list of all cameras. (of course, here I assumed that IMAQdx used for connection to IEEE-1394 camera).
Another way is CameraValidator.exe utility with /ENUM key - this will also enumerates the available cameras.
best regards,
Andrey.
Message 2 of 10
(5,094 Views)
*Solution*
Chris Bolin
LabVIEW Partner Program, CLA
Message 3 of 10
(5,071 Views)
Now why didn't I think of that? 🙂  Thanks Andrey.
Note to admin: I tried to mark the reply as a solution, but an NI employee beat me to it - that's a little egotistical, isn't it?  Why not let the community decide what is and what isn't a solution?
Message 4 of 10
(5,058 Views)
Wait... I didn't mark anything as a solution.  Actually, I just wanted to point out that Andrey had a great answer.
Chris Bolin
Message 5 of 10
(5,043 Views)
I'm not saying that you did, but someone did.  I just figured it'd be a more socially trustworthy system if the person who asked the question could try out the different answers and mark the solution.
Message 6 of 10
(5,019 Views)
Sounds good. It doesn't look like it is marked as a solution any more... maybe it was removed?
Chris Bolin
Message 7 of 10
(5,008 Views)
Yeah - that's odd.  Oh well, I've marked it as a solution, so we're back to where we started 🙂
Message 8 of 10
(4,987 Views)
Hi Chris,
The "Options" for a reply (far top right corner of the reply) allows you to un-mark a message as a solution.
Ben
Message 9 of 10
(4,825 Views)
Message Edited by CXB on 12-03-2008 09:30 AM
Chris Bolin
Message 10 of 10
(4,804 Views)
