Machine Vision
How can I have signal to stop the machine if the last 5 results from the inspection is fail
I'm using labview RT with vision assistant and i want to have a signal to stop the machine if the last 5 inspection result is Fail.
(3,636 Views)
One way to do this would be to output the inspection result to a shift register, and then stop if the last 5 results are Fail.
If you want more specific device, I could help more if I knew more about your application.
(3,626 Views)
How can i make " if the last 5 results from the inspection fail "
(3,609 Views)
Here is the way I would do it in LabVIEW:
Create a counter variable.  Each time the test passes, zero the counter.  Each time the test fails, increment the counter.  If the counter is equal to 5, output a signal.
Bruce
Bruce Ammons
Ammons Engineering
(3,605 Views)
