12-10-2010 01:01 AM
I need infrared thermal camera to detect defects on pipes for my class project. Does NI have a camera that works as an infrared thermal camera and is wireless or can some how be converted to send out a wireless signal...thanks
12-10-2010 01:53 PM
coolrthancoolio,
NI does not make any wireless or infrared cameras. Using the NI-IMAQdx drivers you can communicate with any Direct Show compliant USB camera, any IIDC firewire camera or any standard GigE ethernet camera. You could also use a camera link or analog camera with an NI frame grabber and the NI-IMAQ drivers.
Please let us know if you have any other questions.
Sam K
12-10-2010 03:06 PM
FLIR's A315 and A615 industrial cameras comply with the GigE Vision and GenICam standards, allowing the cameras to be used with the NI Vision Acquisition Software, see
http://www.flir.com/thermography/americas/us/content/?id=17982
07-07-2011 09:02 PM
L503 is widely applied in building inspection, power equipment or electric system inspection, industrial &general maintenance application, fire fighting etc.
11-16-2012 05:38 AM
what about if there are no usb support. I want to use a thermal camera, and use a wireless conection somehow, to make it visible in LabView...
I've seen some videos for the NIDAQ, but this is only usable through usb support. If u have any ideas...
Cheers 🙂
