Machine Vision
Any reccomendations on infrared thermal camera to detect defects on pipes.
I need infrared thermal camera to detect defects on pipes for my class project. Does NI have a camera that works as an infrared thermal camera and is wireless or can some how be converted to send out a wireless signal...thanks
(4,515 Views)
coolrthancoolio,
NI does not make any wireless or infrared cameras.  Using the NI-IMAQdx drivers you can communicate with any Direct Show compliant USB camera, any IIDC firewire camera or any standard GigE ethernet camera.  You could also use a camera link or analog camera with an NI frame grabber and the NI-IMAQ drivers.
Please let us know if you have any other questions.
Sam K
(4,500 Views)
FLIR's A315 and A615 industrial cameras comply with the GigE Vision and GenICam standards, allowing the cameras to be used with the NI Vision Acquisition Software, see
http://www.flir.com/thermography/americas/us/content/?id=17982
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(4,494 Views)
L503 is widely applied in building inspection, power equipment or electric system inspection, industrial &general maintenance application, fire fighting etc.
We are IRay Technology Co, ltd, as a specialized manufacturer and reliable exporter, we offer a full range of IR thermal imaging camera as well as OEM services.
Please link www.iraytek.com.cn to get more info.
Please kindly inform me if you are in need of it! Thanks for your attention and time!
Many thanks and best regards
Connie
IRay Technology Co., Ltd
Http://www.iraytek.com.cn/
TEL:0086-535-6106575
FAX:0086-535-6106530
Skype:iraytekconnie
Email:
sales14@iraytek.com.cn
iraytekconnie@gmail.com
(4,161 Views)
what about if there are no usb support. I want to use a thermal camera, and use a wireless conection somehow, to make it visible in LabView...
I've seen some videos for the NIDAQ, but this is only usable through usb support. If u have any ideas...
Cheers 🙂
(3,890 Views)
