Machine Vision
How can I programmatically modify/delete ROIs of an ImageViewer in .NET
Hello, I am using the NationalInstruments.Vision.WindowsForms.ImageViewer .NET-control of Vision 2009 to display camera images. I take the coordinates of a drawn rectangle Roi to specify a camera crop region. Then I would like to delete/modify/scale the Roi because the new cropped images from the camera have a different size so the Roi is displayed at the wrong position. But all the control's properties are read-only. And if I modify/clear the Roi array (ImageViewer.Roi) I get an exception out of the control. Is there a "clear roi" function or something similar that I have overlooked? Is there another workaround? Thanks a lot for your help, Fabian
(5,189 Views)
The ROIs drawn on the image are stored in a collection (imageViewer.Roi)
imageViewer.Roi.Clear() will clear the ROIs drawn on the display control.
To add a new ROI, you first need to define its contour, then add it to the collection.
Dim roiContour As New RectangleContour(98, 134, 285, 182)
imageViewer.Roi.Add(roiContour)
Vision Development Module ships with .NET examples that you can find here:
C:\Program Files (x86)\National Instruments\Vision\Examples\dotNET
You can also prototype your algorithm using Vision Assistant, and generate the .NET code. This will show you how the different functions can be implemented in .NET.
Hope this helps,
-Christophe
(5,182 Views)
Hi Christophe, but imageViewer.Roi.Clear() ends up with an AccessViolationException: {"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."}. Any idea? thx, Fabian
(5,168 Views)
Can you zip and attach a simple example that reproduces the problem?
-Christophe
(5,165 Views)
Hi Christophe, I think I found the problem: The exceptions occur if you call the viewer's function from a different thread. It works if you invoke the calls on the Form's thread. Thanks for your help, Fabian
(5,158 Views)
