Machine Vision
vision builder labview migration
Migrating vbai to LabVIEW vi without problems.  Vi runs ok.  Close LabVIEW and reopen vi only to have missing vi's.  Migrate vi to project only to have missing errors.  What has to be configured to locate missing vi's?
Dave
Message 1 of 9
(5,183 Views)
Could you please include a simple inspection to reproduce this problem. What version of Vision Builder AI are you using? I just tried the Vision Builder AI 2010 with one of the example inspections and didn't have this problem.
Brad
Message 2 of 9
(5,182 Views)
Hi dg_lbe,
What version of VBAI and LabVIEW are you using?  Also, what VIs appear to be missing?
You could also try the following:
http://digital.ni.com/public.nsf/allkb/9A7FD7E615A18E518625709200778FD5?OpenDocument
Best of luck!
Senior Systems Engineer
Message 3 of 9
(5,157 Views)
I am using 2010.  I would have to close Vision Builder once the vi was generated to solve the issue.
Message 4 of 9
(5,144 Views)
Both LabVIEW and VBAI 2010?  And you notice that you do not have missing VIs once closing VBAI?
Message 5 of 9
(5,139 Views)
Yes, both are 2010.  And yes, once builder is closed no issues loading vi's...
Message 6 of 9
(5,135 Views)
It sounds like your inspection may be using HW resources that can only be used by one application at a time. For example, cameras typcially can only be by Vision Builder AI or LabVIEW but not both at the same time.
You may not be able to have your Vision Builder AI inspection running at the same time as a LV program if they are both trying to use the same HW.
Hope this helps,
Brad
Message 7 of 9
(5,128 Views)
Using a image simulation folder.  Both run fine when both are opened.  When vi is entered into a labVIEW project folder errors occur.  Also when LabVIEW is closed and re-opened errors occur.   The only time errors do not occur is when Builder is closed.
Thanks for your help in this matter.
Dave
Message 8 of 9
(5,124 Views)
Again, could you send a sample inspection to reproduce this. I don't think we're going to get anywhere fast by guessing. If you don't want to put it on a public forum, you can email it to vbai.support@gmail.com
Brad
Vision Builder AI Senior Software Engineer
Message 9 of 9
(5,106 Views)
