Machine Vision
How can I see portable pix map P6 65535 colour depth and display on labview
Dear All
How to read a file with a color depth of Ppm P6 65535 and display it in bmp format
(2,884 Views)
Hi himes,
     From what I know you would need to use your decoder and then save it to the format you would like. Something like what's discussed with more detail here
     I haven't done this myself, but in principle, it should work.
(2,849 Views)
Hi  Cdiaz95
I tried the attached file with the sample I've tried not be successful. So I need support. I even found a sample code forum but could not convert it to any form.
(2,837 Views)
DId running the code of the forum you point gave you an error or did the resulting image just had an issue for you?
(2,826 Views)
Hi cdiaz95
No error. But I can't get the image that should be.
(2,823 Views)
