Machine Vision
"NI Vision Development Module" with .NET C#
I'm interested if new version of NI Vision Development Module is still able to be used within
.NET C# applications?
Best regards!
(4,831 Views)
danilo,
Yes, VDM 2018 still includes the .NET API for developing in C#. You just need to make sure to install the .NET application development support when you run the installer.
-Jordan
(4,765 Views)
Im also interested in VDM support of .NET and Visual Studio 2017.
On the first webpage about VDM is:
You can use it with the LabVIEW and LabVIEW NXG graphical programming environment, C, C++, and C# for Windows systems and LabVIEW for real-time systems.
But in VDM readme is this:
NI Vision Development Module .NET Support
NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
Can we expect update in future versions of VDM or its already dead? And last update 5 years ago is dead for me 🙂 Hopefully it will change with NXG platform?
Thank you
Pavel
(4,537 Views)
