Machine Vision
How can I use texture to identify parts and measure the texture
Client wants to detect and count parts which differ only in texture (roughness,random pattern, etc). Also wants to have a numerical measure of texture.
(3,280 Views)
Can you describe the parts a little better? What kind of material are they (plastic, metal, etc.), and what is the surface finish (rough, painted, polished, etc.)? How much do they differ?
If it is a reflective finish, there are a few techniques for measuring the finish quality (roughness, gloss, orange peel, etc.) which could be used to quantify the texture.
If it is non-reflective (flat color), you could probably use structured lighting to highlight the texture.
I would need more specific examples to have ideas of how to quantify the texture, probably including images of different parts.
Bruce
Bruce Ammons
Ammons Engineering
(3,280 Views)
Bruce:
The surface is flat, non-reflective fabric simlar to a rug which doesn't reveal its weave. Surfaces differ in color. If it was a rug, measurements would ID the rug and determine how smooth & dense its pile is. Lighting varies and is not controllable.
(3,280 Views)
Without controlled lighting, I think it would be very difficult to quantify the texture of the material.
Perhaps if the magnification is high enough, it would be possible to identify individual strands/fibers/etc. and determine the texture from that.
Bruce
Bruce Ammons
Ammons Engineering
(3,280 Views)
