Machine Vision
How do I change the cursor so I can select an ROI?
I am working with VDM2009 in C#.  I have an image viewer and have programmatically added an ROI.  When I go to select the ROI to move it around, the cursor looks like a hand and can't select anything.  I tried setting imageViewer1.Cursor = Cursors.Default; but that had no effect.
How can I select/manipulate my programmatically-created ROI with the mouse?
Many thanks,
Neville
(3,630 Views)
Accepted by nb1forxp
Hi Neville, I believe the default is image Pan, which is the hand. I think you right-click on the image window you should be able to select another tool. Alternatively, you can programmatically the cursor to one of the values of the correct cursor types.
Jeff | LabVIEW Software Engineer
(3,608 Views)
Hi Jeff,
Super!  Thanks so much!
Neville
(3,591 Views)
