Machine Vision
How do I create a pause in my inspection so that I can change a setting on my DUT, then resume with the rest of the inspection?
New to NI Vision and Labview in general here.
How do I create a pause in my inspection so that I can change a setting on my DUT, then resume testing?
I want my inspection to run algorithms on two different image acquisitions, hence the pause to change my DUT settings.  I thought the breakpoint was working well when I am in the configuration interface and I run the state, but it seems like when I run the inspection it skips over the breakpoint and continues onto the next inspection step without waiting.
(4,003 Views)
could you send your vi?
for creating pause the best way is use flat sequence with 3 frame and put one while loop in second frame so until you do not press to make stop the while loop third part will not start
(3,996 Views)
Accepted by VictorHC
Are you running Vision Builder AI on Windows or on a remote target? If you have a remote target, which one?
On Windows, you can use a User Input step located in the last tab of the Vision Builder AI tools palette.
It will let you display a dialog that will pause the inspection until you click on a button.
(3,990 Views)
Hey that sounds right. I already used that function to enter a serial number. Thanks
(3,977 Views)
