Machine Vision
How do I display an array using vision tools
I have an array of data that I would like to display on the screen.  When I use the picture functions they put a border around the image which is not helpful.  I noticed the "IMAQ WinDraw" and used it to display data I got from a Tiff file (without the border)...but there doesn't seem to be a path from an array directly to the windraw function without going through the file process.  I'm sure I have missed something...but what is it?
Thanks in advance for your help.
The Hummer
Message 1 of 15
(6,383 Views)
Y do need picture functions when u have a direct function?
Message 2 of 15
(6,380 Views)
Actually, if I understand your question correctly, you will just need two functions:
IMAQ Create
IMAQ ArrayToImage
You can then use the Front Panel control "Image Display" to display the image.
Chris Bolin
LabVIEW Partner Program, CLA
Message 3 of 15
(6,346 Views)
I do not seem to have IMAQ ArraytoImage anywhere in the help files or in the system.  Where can I acquire such a wonderful piece of software?
Not Humming.
Message 4 of 15
(6,342 Views)
Hey, Chris....no kidding.
I have the vision tools and LV Developer Suite and there is no IMAQ Array toImage that I can find.  Is there one in the vision developer module?
Message 5 of 15
(6,331 Views)
Look here.  It will be in this sub-palette
Vision and Motion >> Vision Utilities >> Pixel Manipulation
Randall Pursley
Message 6 of 15
(6,329 Views)
Hummer,
                Can you post a screen shot of your function palate?
Message 7 of 15
(6,310 Views)
The only function in the pixel manipulation palate is the IMAQ ImagetoArray ...  that's it.
Should there be more?
Sorry ... havn't downloaded the Image posting stuff yet...
Hummmmm
Message 8 of 15
(6,303 Views)
It sounds like you need to install the Vision toolkit again.
Randall Pursley
Message 9 of 15
(6,301 Views)
it sounds like you need to install the Vision toolkit again.
NO no wait.I remember answering a similar question a month ago in this forum.Let me see.
Message 10 of 15
(6,298 Views)
