Machine Vision
How do I do image acquisition using an external trigger in VB.net?
I am using an IDS USB camera and need to use an external trigger.
Do I need to configure the camera in MAX in order to do this? What IMAQdx command(s) do I use to do this?
Thanks!
(4,479 Views)
Yes.. You can configure the same in MAX..
Also find this also helpful http://www.ni.com/white-paper/5750/en
Silver_Shaper | CLD
(4,471 Views)
