Machine Vision
How do I export an IMAQ blob from LabVIEW into a DXF file?
Has anyone created a utility to export a DXF file from an IMAQ blob? (LabVIEW environment).
I have a project that needs to save an IMAQ image to a DXF file. The image is a BLOB of some part that needs to be machined. Because the parts might require manual touch-ups, the original file is not suitable. IMAQ will be verifying the touch-ups, providing vision calibration and exporting the final part dimensions to be machined.
Kenneth Klimkowski
(3,491 Views)
Kenneth,
LabVIEW IMAQ can directly save still images to file in the following formats (BMP,JPEG,PNG,TIFF,AIPO) You might be able to have a 3rd Party software change one of these formats to DXF file.
Austin Talley
Applications Engineering
(3,491 Views)
