Machine Vision
How do I identify the current IMAQ vision version, including updates ?
I would like to identify the installed version of LabVIEW on an old machine, including the IMAQ vision updates. Where do I look ???
(3,807 Views)
A quick way to find out versions of all National Instruments software/driver installed is to go to MAX (Measurement and Automation Explorer) and click on Help->About MAX->Tech Support then the System Tab.
If your system is from the pre-MAX days, then you can get the version numbers in Add/Remove Programs in the Control Panel.
Hope this helps.
Ken
Applications Engineering
(3,807 Views)
If i follow your guidence i get the following result:
Operating System(OS)
OS Version
OS Info
Processor
Number of Processors
Physical Memory
Drive c:\
Nothing else.
Max have a Configuration option for software. But this does not contain any information about IMAQ vision software update versions. 602,603 or 604.
(3,807 Views)
