Machine Vision
How do I stitch two or more images using Advanced Imaq-Vision or Vision Builder ?
Im trying to use IMAQ and Vision Builder to recreate a cross sectional view of a fiber (cylindrical) by taking a few shots over the length of the fiber, from four different angles (0, 90, 180, 260 degrees).I need the stitching to recreate the whole fiber view, and also need to recreate the cross section at couple of places over the fiber's length.
(3,631 Views)
There are not any tools available in IMAQ to do the type of image stitching you describe that I am aware of. It sounds like you will need to do some image mapping to correct for distortion, etc. It will be difficult to determine the proper mapping and calibrate the system.
I have created some tools for image mapping, but they would not be sufficient for this type of project.
Bruce
Bruce Ammons
Ammons Engineering
(3,631 Views)
