‎01-17-2008 03:06 PM
‎01-17-2008 06:11 PM
‎01-18-2008 07:01 AM
Eric,
Thanks for the suggestion. I did that and now have my cameras numbered as I wanted, but there's another problem. I believe the iid files are supposed to reference the camera icd files so that changes I make in MAX to camera settings are saved. Well this wasn't happening: the iid files did not reference the icd files.
I opened the iid files in Notepad and manually entered the icd file reference but it hasn't made any difference, MAX still isn't saving my camera settings.
Any further suggestions?
N
‎01-22-2008 09:01 AM
Hey N,
I've been looking into your issue and I wanted to make sure that after you have modified your camera attributes (which is what I assume you are doing), that you are pressing the save button at the top of the window in MAX. This should record those changes to your attributes so that the next time you open MAX or unplug your camera and reconnect it, it will come up with the new settings that you saved previously. Let me know if this is not the case. I tested this out on my IMAQdx camera earlier this morning to make sure that this is the case.
Take Care,
