Machine Vision
How do write an image threshold to single rectangle?
Message 1 of 10
(5,254 Views)
Create a mask image using the rectangle, then use the mask over the input image. Then apply the threshold. You can also extract and do that. as far i know, there is no way to apply only to the part of image directly.
logic
Message 2 of 10
(5,253 Views)
Problem in that  I need to allocate a part of a picture to apply threshold but see a picture. I see only the allocated part.
Send an example.
Beforehand thanks.
Message 3 of 10
(5,247 Views)
Send an example.
Beforehand thanks.
Message 4 of 10
(5,241 Views)
Thats true. You will have only the extracted part left as a new image. If you need to place it on original image, you can use Image to Image vi. But remember that your thresholded part will be of binary and the other will be 8 bit. Usually this will be used only for diaplay purpose. Example attached.
logic
Message 5 of 10
(5,232 Views)
To eat with the image on which it is drawn Rectangle. To me it is necessary to make Threshold only to Rectangle, instead of to the image. A problem in that that I on an output want to see the image together with Threshold. After application of a mask the image decreases on size Rectangle. As to me it to make.
Please it is better an example.
Beforehand thanks.
Message 6 of 10
(5,230 Views)
Did you looked at the example attached with my previous posting?
logic
Message 7 of 10
(5,224 Views)
Excuse there is no many thanks
Message 8 of 10
(5,219 Views)
Look my example. Yours it not that that is necessary to me. The same effect with rectangle. In my example the image is necessary for me does not vary, and you cut out Rectangle. Have removed a part of the first image. The problem to not cut out - to impose result Threeshold but not on the image. Only on Rectangle. At me on the image.
Message 9 of 10
(5,214 Views)
I could not understand what you are looking for. Contact me through yahoo, if you need further help.
logic
senthil_logic@yahoo.co.in
Message 10 of 10
(5,211 Views)
