Machine Vision
How to SHOW/HIDE a boolean indicator based on and inspection step (PASS/FAIL) in vision builder?
My problem is how can I show/hide and indicator (boolean) in vision builder based on an inspection step?. I mean I want to show a PASS indicator in the inspection interface on green if the step passes as good, otherwise I want to show the FAIL indicator on red if the step fails. Hope someone can help me with this issue and also if this information is enough to understand my problem. Thanks and regards.
Jose M.
(2,427 Views)
Accepted by JOEMEN
Hi JOEMEN,
You can use the Custom overlays. You can get more info about it in the section 6 of this tutorial:
http://www.ni.com/pdf/manuals/373379h.pdf
Regards.
(2,368 Views)
