12-23-2008 04:41 AM
Hi, I am working on project where i want to measure dimensions of some parts within 40 micron accuracy.
I used 8 mega pixel camera and my area of image is 60 mm x 60 mm.
I have devloped software in which i am searching template in area and locating object and doing my measurements.but the problem is
when i am measuring dimension of any object repetadely i am not getting same dimension.i am getting error of 2 to 3 pixels for the same measurement.
Can somebody help me?
12-23-2008 09:47 PM
When you set up pattern matching, did you use sub-pixel accuracy? That can frequently improve the accuracy.
Bruce
12-24-2008 12:59 AM
Thanks but i tried it still i am getting 2 to 3 pixel error when i am shifting my object in my inspection area.
12-24-2008 09:30 AM
Can you post a picture so we can see what you are trying to locate? That may help.
Bruce
