Machine Vision
How to assign original camera number in MAX for the replaced firewire camera
I have 8 1394A cameras (cam0 to cam7)  on a machine and cam3 went bad.  I cut and pasted the cam3.id and cam3 config file to a temp directory.  I plugged in the replacement camera and MAX assigned it cam8.  How can I change cam8 to cam3?   In the meantime I opened cam3 config file and copied/pasted contents to cam8 config file.  I then changed references in my VB6 database software of cam3 to cam8.
(3,369 Views)
Accepted by topic author DelphiDan
Hi delphi Dan,
You can right-click on the camera in MAX and select 'rename'. Then select cam3, or whatever ID you want.
Jeff | LabVIEW Software Engineer
(3,344 Views)
