Machine Vision
imaqExtractFromRing - "Not an image" fatal runtime error
Hi.
I integrated the ring acquisition into my program. I made and initialized all the variables as in the NI ring example, but something is wrong.
Image    *currentImage;           // global
int            imageToExtract;       // global
int            imageExtracted=0;   // local
Sid ok,
currentImage =  imaqExtractFromRing (Sid, f.imageToExtract, &imageExtracted);
At this line the program cracks with the Fatal error:
Function imaqExtractFromRing (errorCode = -1074396120 [0xbff60428]). Not an image
A have checked all the variables just before execution of this line, and it seems to be all right. After a week still haven´t got any idea what can be wrong.
(4,229 Views)
What is the buffer name you have used?
(4,226 Views)
 status = imaqSetupRing (Sid,                                  images,               bufferCount,      skipCount,      IMAQ_NO_RECT);
[int          imaqSetupRing (SESSION_ID sessionID, Image** images, int numImages, int skipCount, Rect rect); ]
unsigned short int    bufferCount;              //global
Image  *images[NUM_RING_BUFFERS];   //global      <-   this one
(4,219 Views)
Maybe the problem is that I`m using imgGrabSetup (Sid, TRUE); and ImaqBuffer = NULL; instead of imaqStartAcquisition (Sid); but my basic funcionality is based on img session. If it would be it, I have no idea how to solve it.
(4,197 Views)
(4,150 Views)
Thank You for the reply. I have read the article and any tip that I might take from it is: always create 8bit image buffers allocated with IMAQ Create when you want to extract some info from your picture, what I`m doing.  It`s not that.
(4,146 Views)
