Machine Vision
How to control RS 232 image intensifier
Hi all,
I have a videscope VS4-1485 image intensifier which got RS-232 communication. The instrument comes with a software (not labview) to control the gain and gate delays. But I need to control the intensifier with Labview as I do with my camera. can any one tell me what further setup is required to control the RS-232 instruments with LabView, I know I can use Visa serial read and write but does I need any special SCPI commands? do i need a DAQ card?
Please let me know.
AG
(5,160 Views)
Accepted by AnkitG
usually the manual of the device should state (if applicable) the command arguments to be sent over the serial port. Did you check the documentation? You should just need a RS232 cable and proper command format in order to communicate.
Should be fairly easy, I suppose.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,157 Views)
K
Thanks a lot, I will check with the vendor as the datasheet and manual doesnt have any command list. the manual only state that the device have  RS232 control.
AG
(5,151 Views)
